Need Clutch for Raptor....???
Old Jan 21, 2003 | 06:48 PM
BajaDS650's Avatar
Default Need Clutch for Raptor....???
The clutch on my dads Raptor is going out. He wants a new one. What is the best and where should we get it from??
BTW, he will probably never do anything more to it than put a pipe on, so it doesn't have to be super heavy duty. Also, is there anywhere that tells how to replace the clutch?
Thanx for the help.
Old Jan 21, 2003 | 09:30 PM
xbox74's Avatar
from what i have been told on this forum go with the gytr set up straight from yamaha
Old Jan 21, 2003 | 10:00 PM
AdamsBadDS650's Avatar
To replace it, it's pretty simple. Just start by taking off the right side footpeg and brake pedal, then take off the clutch cable, I think that's all. then you have to take off the oil filter, drain the oil, drain the coolant, and take off the coolant pump cover. There is a little bolt that holds on the oil filter, you have to remove that. there is one bolt inside where the coolant pump was (8mm) remove that. You then have to remove all the bolts around the outside (all 8mm) there is some bolts guarded by frame rails, and you have to have some pretty flexible drivers, and wrenches to reach them, but I think it can be done. After the side cover is off, there is the clutch pressure plate with 5 bolts, unscrew the 5 bolts, 1 turn at a time in a criss-cross pattern. Then the springs will come out, and so will the pressure plate, then the clutch. Voala!
Old Jan 21, 2003 | 10:06 PM
xbox74's Avatar
there are service manuals on cd for sale on ebay that show you how to work on the machine
Old Jan 21, 2003 | 10:19 PM
Turbo33's Avatar
Whatever you do,DO NOT use a Barnet clutch in a raptor!!!!!!!!!!!!!!!!!!!!!!
Use a GYTR. you can get it from your Yammy dealer!!!!!!!
Old Jan 22, 2003 | 02:11 AM
BajaDS650's Avatar
Thanx for the input guys. Looks like I'll be shopping for a GYTR clutch. Then after that is fixed.....we wait for the tranny to fail!!![img]i/expressions/face-icon-small-disgusted.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
