400 ex wot adjustment
Old Jan 27, 2003 | 05:42 PM
whatwasthat's Avatar
Default 400 ex wot adjustment
I have heard so many people say that the throttle is set conservitally low, what do i have to adjust to get true wot?
Old Jan 27, 2003 | 06:27 PM
DirtDiggler's Avatar
I would like to know about this as well.
Old Jan 27, 2003 | 08:32 PM
dariusld's Avatar
Go to exriders.com and search throttle adjustment for indepth coverage. Not all 400's aren't adjusted correctly, just some. To check yours, take off the boot on the air filter side of the carb.. Look past the choke and when you push the throttle there is a "slide" that lets air into the engine( you might have to take the carb off to see in). If on full throttle the "slide" isn't all the way to the top, then adjust the throttle. I don't feel like typing it all so go to exriders.com...throttle adjustment
Old Jan 27, 2003 | 09:41 PM
Milkweed's Avatar
If all else fails, take it to a shop (not dealer) and they will charge you around 20 bucks and they will adjust for you. For all the lazy people like me [img]i/expressions/face-icon-small-smile.gif[/img].
Old Jan 28, 2003 | 12:04 AM
i have no problem doing it myself just curious as to what was needed, if i knew it was as easy as this i would have done it a long time ago, and even if the carb is opening up all the way, im sure it would be a good thing to take some slack out of the cable
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
