front diff filler cap
Old Feb 1, 2003 | 06:55 PM
packardbell15's Avatar
Default front diff filler cap
has anyone else cracked the front diff's filler plug, because i did. it has a hairline crack on it and is not useable. i heard this little snap and knew what had gone wrong. so i ordered one, but won't be in till next week. does anyone know of a temporary plug that would work, or does anyone have a replacement on theirs that isnt from kawi. if so can someone tell me where they got it.
thanks
Old Feb 1, 2003 | 09:26 PM
nyroc's Avatar
Did you over tighten? Sorry, I don't know what to tell you.
Hmm, I am wondering if this cap is something I should get and extra one to have as a spare.
Old Feb 1, 2003 | 09:29 PM
NovaKaw650's Avatar
Just snug is the key to tightening filler and drain plugs.
Old Feb 1, 2003 | 10:17 PM
roscoe69's Avatar
Packardbell15
fill it full of silicone and let it set long enough to set up this will keep the water etc out untill you get a new one.
Old Feb 2, 2003 | 12:18 AM
Nightryder888's Avatar
whe ni busted my rear diff. cap i just put a piece of duct tape over it while it was sitting in the garage
Old Feb 2, 2003 | 12:20 AM
yeh i did a search for your old post about that and found it.
i just put mine in not even a turn so it would keep stuff out, it is just that it will leak when riding.
did u just order a new one, and if u did how long did it take your dealer to get it.
when i snapped mine, i knew it happened because it started to turn easier. i dont think it screwed up the threads on the diff, did it on yours? now im paronoid over my engine draing plug and rear diff plug. do u usually tighten your engine and diff plugs pretty tight?
Old Feb 2, 2003 | 10:57 AM
i just went to the dealer and they had one in stock so i got it, it was around $15, so my grandpa threw a hissy fit and we got it for fre
the reason mine snapped is because we had a crappy torqe wrench that didnt go down to 17ft lbs so we just guessed at what it would be. it didnt bust the threads in the case but it did shred some threads off the cap so we just drained the oil and flushed it out by running some more oil through it.
when i tighten my plugs i just do it by hand not with a torqe wrench and it works just fine
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Sportsman850
Jul 31, 2015 04:25 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
