Tire preasure for a woods rider?
Old Feb 4, 2003 | 03:16 PM
MudStud's Avatar
Default Tire preasure for a woods rider?
I have always run 6.5 in my tires.. I run the 22 Razrs and currently run 6.5.. I was just wondering what the consensus was for tire pressure. What produces the best tire ware?
Old Feb 4, 2003 | 03:46 PM
02BAJA's Avatar
I run 6 psi for trail riding on my Razrs.
Old Feb 4, 2003 | 08:11 PM
buttfungus's Avatar
I have always run 5 psi in my razrs and seem to do ok.
Old Feb 5, 2003 | 04:42 AM
1prokiwi's Avatar
i used to run 5 in my shredders , then i tried 4 and noticed i got better hookup and was a second or two faster ....... too much wheelspin with any more
cheers
Prokiwi
Old Feb 5, 2003 | 10:44 AM
HillbillyDS's Avatar
3 psi seems to work great in the woods for me with XCT's.
Old Feb 8, 2003 | 11:02 PM
brad650's Avatar
i use about 7 cause if you hit a rock just right hard, you dent up your rims unless you got enough pressure, lots of rocks sticken out where i ride
Old Feb 9, 2003 | 03:34 AM
Hightower's Avatar
I run different pressures for the locations I'm at. For optimum traction I go down to 4psi, but in rocky terrain I go up to 6 or7. I've had flats from the tire bottoming on a rock with too low pressure, and the tire rubber gets pinched by the rim and cut. Its hard to fix a 3/4" gash on the trail with plugs!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
