Clutch Balancing
Old Feb 11, 2003 | 10:29 PM
NCScrambler's Avatar
Default Clutch Balancing
I was wondering If anyone knew where I could get my drive clutch balanced? I had my drive clutch apart last summer changing springs and when I tightened the cover one of the bolts broke flush with the inside clutch sheave. I work In assembly of forklfts and broken bolts are a common thing so I did what seemed normal and drilled the broken bolt out and re-tapped it. Well, the thing Is when I drilled It out, I also drilled a little bit of the aluminum In the clutch. I haven't really had any problems since but I wondering If this Is enough to throw the balance off and will I be re-building the bottom end soon because of It? If so, where could I get It balanced at? If anybody has any ideas I would appreciate It. Thanks
Old Feb 11, 2003 | 10:35 PM
Bubba297's Avatar
Well, you might get mixed opinions on this. If it is just a tiny bit, I wouldnt worry about it. Unless you get a balanced set of clutch weights, they can be a gram or two different from each other. So there can be a slight variance, but always the better idea is to have a balanced assembly. Hope this helps make you feel better.Bubba
biggin's Avatar
Old Feb 11, 2003 | 10:43 PM
That is what I was hoping to hear!! I didn't think It would make a huge difference, but I wanted to see what someone else thought. Thanks Bubba!! [img]i/expressions/face-icon-small-smile.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
