Spring Rubbers?
Old Feb 11, 2003 | 10:52 PM
Matt650's Avatar
Default Spring Rubbers?
Hey yall
i have an 03 prairie 650, and as all of you know that the front struts can be a little soft, letting the nose dive in the corners. i had an idea today and all you nascar fans know what i am talking about. what if instead of buying preload adjusters for the front, if i could put a spring rubber in the spring and change the compression ratio? maybe they are ready make these for atvs but i have never heard of them. i would probably buy a spring rubber and have to cut it to fit in the spring. i found some for only 20-30$ a piece. a lot cheaper than the preload adjusters. just wanted to hear what you guys think about my idea. thanks, i apperciate your input.
Old Feb 11, 2003 | 11:25 PM
nyroc's Avatar
Better than nothing, but the progressive kit is better.
Old Feb 11, 2003 | 11:40 PM
Matt650's Avatar
I know that the preload kit would be a more permenat solution, but i thought that preloads only changed the load rating, and ride height. not the compression ratio? i am wrong?
Old Feb 12, 2003 | 06:54 AM
nyroc's Avatar
The progressive kit comes with different spring and an adjuster. From what they say it is totally better than just a preload system.
Old Feb 12, 2003 | 11:43 PM
bfb750BF's Avatar
There is a pair of Progressive Springs right now on bid at ebay.
ReconBayou
Oct 16, 2019 02:24 AM
franklyme
Oct 21, 2016 07:18 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
