WARN 2000 winch Help Needed...
Old Feb 16, 2003 | 07:48 PM
jcrawford1's Avatar
Default WARN 2000 winch Help Needed...
I have a warn winch question?
I was given a warn 2000 winch from a friend who said it didn't work. I tried it by putting power ot it and the motor did not turn. I took it apart and it was gunked up inside. I cleaned it and now the motor turns. The gear box gear assembly was rusted up and clogged as well. I need to know how much and what type grease I should use in the gearbox.
Thanks for any and all help.
jim@mx14.com
Old Feb 17, 2003 | 01:52 PM
jimmyjack's Avatar
Warn Industries uses a special type of grease inside their winches called Arrowshell 17, buy it's not readily available to the public. Try doing a search over the internet and you might get lucky and find someone that carries it. If no luck, you should use a grease that is a high moly EP base type. You could also call Warn at (800) 543-9276 and they should be able to stir you in the right direction.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
cboler9
Sep 24, 2015 08:35 PM
