Less then .002 on the intake..Should I??
Old Feb 27, 2003 | 11:44 PM
MudStud's Avatar
Default Less then .002 on the intake..Should I??
I have less then .002 on both of my intakes. I can't measure less then .002. So my guess is they are at .001. Should I pull the shims and get .005 smaller shim so I would estimate the gap at .006? or should I get a smaller feeler gauge to be more correct??
Old Feb 27, 2003 | 11:54 PM
ThePunisher's Avatar
That would suck if you ended up with .006 on those intake valves. But you would still be allright. You want to be right at .004 or .005 if you can help it.
Old Feb 28, 2003 | 12:17 AM
RoostinOnYou's Avatar
mudstud .006 will be fine. [img]i/expressions/face-icon-small-wink.gif[/img] ,the difference in one thousands is minimal, as long as your valves are not to tight. if to tight the clearance shrinks some. with the intake clearance your running now you could burn up a valve. a little more clearance is better than not enough. the power difference in in one thousands is non existent!!![img]i/expressions/face-icon-small-wink.gif[/img]
rider1rides
Aug 27, 2013 09:49 PM
th3hunt3r52
Oct 9, 2012 12:24 AM
mylittlebigfarm
Mar 1, 2012 09:21 AM
Hunternutz
May 11, 2006 12:20 PM
MEAN1
Jan 16, 2002 06:10 PM
