Less then .002 on the intake..Should I??
I have less then .002 on both of my intakes. I can't measure less then .002. So my guess is they are at .001. Should I pull the shims and get .005 smaller shim so I would estimate the gap at .006? or should I get a smaller feeler gauge to be more correct??
mudstud .006 will be fine. [img]i/expressions/face-icon-small-wink.gif[/img] ,the difference in one thousands is minimal, as long as your valves are not to tight. if to tight the clearance shrinks some. with the intake clearance your running now you could burn up a valve. a little more clearance is better than not enough. the power difference in in one thousands is non existent!!![img]i/expressions/face-icon-small-wink.gif[/img]
