Another Polaris Four Wheel Drive Question
A while back there was a question about how the Polaris four wheel drive system works. People said that there is a one way hub to the front wheels, My question is how do Polarises have four wheel drive in reverse?
Its a two way hub that is electomagnetically controlled. It does not matter which way the input shaft turns as long as the coil is energized and holds the hilliard clutch, it will lock the hub to the input shaft using overrunning rollers. Its real simple but you really need to see it to really understand it.
