Another Polaris Four Wheel Drive Question
Old Apr 18, 2000 | 06:37 PM
XLR8's Avatar
A while back there was a question about how the Polaris four wheel drive system works. People said that there is a one way hub to the front wheels, My question is how do Polarises have four wheel drive in reverse?
Old Apr 18, 2000 | 10:48 PM
Rammer's Avatar
It's a one way hub,determined by which way the axle rotates. The hub can turn faster than the axle, but not slower, forward or reverse.
Old Apr 18, 2000 | 11:03 PM
Charlie's Avatar
Its a two way hub that is electomagnetically controlled. It does not matter which way the input shaft turns as long as the coil is energized and holds the hilliard clutch, it will lock the hub to the input shaft using overrunning rollers. Its real simple but you really need to see it to really understand it.
Old Apr 19, 2000 | 09:11 AM
sxr6's Avatar
Is Polaris a true 4wd like Suz locker in that both front tires drive & makes it VERY hard to turn?
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
ZJnut
Dec 30, 1999 08:33 PM
caldwell
Oct 28, 1999 03:30 PM
