clutch
Old Mar 5, 2003 | 12:15 AM
ridered62's Avatar
Default clutch
my friend has a 350x and when it got icy his clutch stopped working from sliding around on it and stuff i guess...but anyways...when he puts it in gear and lets out the clutch the tires kind of kick but it wont move...but if you lift the back end up the tires will spin slowly...i was thinking it was the pressure plate...but maybe the whole thing...what do you think...thanx for the help
Old Mar 5, 2003 | 09:26 AM
dzzy's Avatar
Default clutch
assuming clutch cable is adjusted correctly, the most common cause would be "cooked clutch plates" , you will find them underneath the right sidecover. there will be a number of metal and fiber plates, (always 1 more fiber than metal) that you will need to replace. If they are burnt, you may be able to "smell" the evidence by whiffing where you add oil.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
