Prairie 300 belt/speed
Old Mar 5, 2003 | 10:22 PM
KawiCanuck's Avatar
Default Prairie 300 belt/speed
Hey guys/gals,,,, Very new to automatic fourwheelers,,have a 2002 kawi Prairie 300 4x4,,I do know that using low gear extends belt life span,,,but at what speeds should I be in high range,,, Thanks for your feed back,,,Plus anyone else with one,,any problems or complaints,,thanks,,,,,Eric
Old Mar 6, 2003 | 03:34 PM
altakawi's Avatar
My wife runs a 2000 kvf 300 with about 2000km on it,great bike ,the only problem we have had with it is the bolts coming loose on the exhaust manifold going into the head. it will start to rattle on you,good luck with your new toy!
Old Mar 6, 2003 | 07:54 PM
400PrarieXLT's Avatar
I have the same machine only a 400. I use low a lot on the trail, and I absolutely hate when we come off a trail onto a gravel road or a bigger wider fire road. I have to allmost stop, throw it in high, then catch back up, (no trouble there yet). If it were just me with this problem I would leave it in high and just change the belt more often, but its fun, because the Polaris 400 sportsman has the exact same problem, so we get to do the low to high drag race.
too long, guess to answer your question, for anything consistently over like 25 MPH, unless towing or climbing big hills, I go to high. Happy riding!
Old Mar 6, 2003 | 08:40 PM
kawrob's Avatar
i have a 01 300 4x4. i've been real pleased with it so far. theonly real problem i've had is the front bearings start rocking in the spindles wich causes it to make a clicking sound when you turn. it's something that is easy to repair. they use red locktite on the bearings and it holds up real good. mine has gone 700 miles with no problems. the muffler bolts came loose too so i used locktite and thats been fine since. as far as low or high i only use high on long flat rides. i just installed a warn winch so i might need some stronger springs in front.
Old Mar 6, 2003 | 08:46 PM
Nightryder888's Avatar
my grandpa used to have one before he traded it for a 400. no problems except for when you started goin just enough to make it move it would click and jut forward a bit at every revolution of the tires never did it when goin faster than 5mph. never figured that problem out
Old Mar 6, 2003 | 10:07 PM
KawiCanuck's Avatar
Thanks everyone,,,,Still breaking it in,,,was a little worried because I was using on ice,,I am only using half or less throttle but I am keeping it in low,,sounds fine ,,runs fine,,but I guess I should use high on ice... It is just so smooth sounding compared to my 300 bayou 1995 I had previously that low range seemed ok,,,but i did think it was a little {hot},, Same engine and all but lots of extra pounds and automatic plus 4x4 ,,I guess it will run hotter no matter what..
Old Mar 7, 2003 | 10:01 AM
Hey Kawrob,
I have same front weight problem, winch and loaded box on front rack makes it pretty heavy. Does anyone make a stiffer front spring for the 300/400 Prarie's? I was wondering if the adjustable springs from the 650 might fit our bikes. would help a lot.
Old Mar 7, 2003 | 10:08 AM
KawiCanuck's Avatar
400PrairieXLT,,,If the 650 springs are not inter-changeable ,,how about trying the spring stiffener inserts used when a plow is installed,,,just an idea
Old Mar 7, 2003 | 06:49 PM
kawrob's Avatar
check out progressive springs. they make a set for the 300 up to the650. i'm not sure about the name of the place but i think its called royal distributing. they had the best prices.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
