trx250r ignition
Old Mar 6, 2003 | 12:32 PM
BrotherQuad's Avatar
Default trx250r ignition
Who makes a decent aftermarket ignition set-up for a 250r.
Old Mar 6, 2003 | 01:15 PM
trx250rjb's Avatar
i can get you an ESR CR unit.
Old Mar 6, 2003 | 02:56 PM
vilnrk's Avatar
i have a msd unit. you can get it from ftz racing.
turbo bobby
Old Mar 6, 2003 | 03:33 PM
DaBeechMan's Avatar
rjb, what is your cost on one of eddies units?
I feel the esr (CR) is the best unit on the market, simply because its a bolt on and its very reliable. With the msd you have a battery you need to run, and that can be a pain if your lazy like i am. So other ignitions are the pvl which is a "set" ignition where you only have 1 set timing advance or retard (opposed to timing curves), these work great on drag bikes, and there is also a dyna system with also works good on drag bikes. If your just screwing around i would go with the CR ignition because of its light weight and versatility
Old Mar 6, 2003 | 03:38 PM
trx250rjb's Avatar
since it is a honda unit there isnt much mark up and i could probably barely beat there $489 cost.
Old Mar 6, 2003 | 03:42 PM
DaBeechMan's Avatar
eddie must make a butt load of money off that then. Since eddies parents own one of the huge honda stores over there.
Old Mar 6, 2003 | 07:14 PM
briansgi's Avatar
I have the ESR CR250 ignition, got a good deal on it for $400. But check these out on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=34284
http://cgi.ebay.com/ebaymotors/ws/eB...category=10066
Old Mar 7, 2003 | 02:30 PM
AlkyBurninX's Avatar
DaBeechMan, I have one of the older internal rotor Motoplat ignitions for my drag 250R. Would you recommend staying with it, or going with the newer PVL internal rotor igntion, or some other ignition setup? I have studied up on the banshe stuff, but am new to the R building.
Old Mar 7, 2003 | 04:35 PM
DaBeechMan's Avatar
To be honest alk, id recommend the pvl (or motoplat) for the banshee's that do their straight line drag's. They seem to like them. On the honda's they REALLY like the benefit of the timing curves, i know a lot of people arent happy with their pvl's on their honda's, but they are sunk so deep in the money that they cant afford to at least try the cr or msd. Id stick with the cr personally because the advantage of the cr curve really helps in more then just racing (even though they dont do bad on the hill). We have the new pvl setup, and i havent even paid attention to the older motoplats to be honest. I'll see if i cant get some info for you though. Besides, its a real bit*h to try to kick a honda over with a +_ advance? foghettaboutit!
Old Mar 7, 2003 | 05:09 PM
The main reason I like the idea of the internal rotor was the increase response and acceleration due to less flywheel weight. In your experiences, do the R's do better with a heavier flywheel or lighter ones in DRAG ONLY situations? As you might remember, I have the dyna for my banshees and the programming software. I love this ignition, but the motoplat came with the engine so I thought it might be better. I don't like the MSD because it uses the seperate battery that must be kept charged.
I am not really familiar with the rotor ignitions. Do they only have one degree of fixed advance, or is it just a fixed curve? Is the ESR CR adjustable?
Thanks for your help. Richard
