Can you bore the TM42
Old Mar 6, 2003 | 02:31 PM
KMDuner's Avatar
Default Can you bore the TM42
Is it even worth it? Just thinking of some ideas.
Old Mar 6, 2003 | 02:42 PM
SANDMAN430's Avatar
they taper bore the carbs on the snowmoblies here all the time, so my friend has the woods stage one, and had a stock machine. so he had his taper bored and we couldn't tell a real change one way or the other, i did have the carb on my sons blaster and heis pleased with the results, wins a lot of races. the guy said the way he had to taper bore the stock carb it was hard to do. anyways that is what we have seen , seems it should work but, i wouldn't try at this point for a little more you could get a 44mm lectron
Old Mar 6, 2003 | 03:11 PM
KMDuner's Avatar
I have the 44mm Lectron and want to try something else. I'm pleased with the carb but I'm curious about other carbs.
Old Mar 6, 2003 | 04:18 PM
KMDuner's Avatar
Anyone interested in a hsr 42 should check ebay, there is one there for about $110 and new ones for $220
Old Mar 6, 2003 | 04:28 PM
lilnotts's Avatar
where would the hsr help me on my quad? on bottom?
Old Mar 6, 2003 | 05:31 PM
KMDuner's Avatar
It's the same as the TM, it would help on bottom but I would think that you'd feel a better pull all the way thru.
Old Mar 6, 2003 | 05:59 PM
Musthavefn's Avatar
I want the hsr 42. Are you talking about the Harley carbs on ebay or where are they. I guess I could buy the new cable from RW and direct mount the filter or would I still be able to use the air box.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 6, 2003 | 06:31 PM
KMDuner's Avatar
here
You should be able to use your stock cable and throttle. Stock is 42mm so it'll open up the hsr just fine. You'll be able to use your air box or go with the carb mount.
Old Mar 6, 2003 | 09:32 PM
glamisds650's Avatar
the tm42 is much better than stock, however i'll be putting mine up for sale too soon. I'm installing the dual 39's this weekend
Old Mar 6, 2003 | 09:44 PM
lilnotts's Avatar
wat benifets will it give me?
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
