Banshee rebuild help
Old Apr 24, 2000 | 06:15 PM
SteveNB1's Avatar
I have a 94 Banshee. At the end of my last dune trip, I noticed a hairy tick sound in the motor. I shut it down and have since tore it apart.
Come to find out I lost a chunk of my left piston which resulted in some cylinder wear and the head dinged. Sucks but now I get a cool head and a bore job (if its not to bad). My question is were did the 1/4 in. of piston and ring go. Hopefully out the exhaust? It still ran fine. Do you think it effected the crank and/or rod? Also both rods seemed alittle sloppy. Do they usually have a hair of play?
By the way I blame the failure on problems I've had with foam filters. The stock one let enough sand in to foul the plugs and the Pro Design foam let about 50% less sand in.
Old Apr 25, 2000 | 09:41 AM
fakie99's Avatar
well, first of all, you are right -- the foam filter is junk. i just upgraded to the k & n device. secondly, i too have lost bits of piston and/or ring. my guess is that the piece of piston, if it was lost from the piston skirt, is somewhere in the crankcase. if i were you, i think i would tear it apart to find out where everything went. the rods do have some horizontal freeplay -- that is, the piston shold move slightly back and forth on the connecting rod pin -- but it shouldn't move up or down on the pin when pulled. good luck. and btw, is the machine stock?
Old Apr 25, 2000 | 12:04 PM
SteveNB1's Avatar
I have digital pictures to show the damage, but I don't know how to post them in the forum. If anyone is interested reply and I can show them via email. They also show the sand from the foam junk.
Old Apr 25, 2000 | 07:20 PM
mongoose's Avatar
yeah, sendem over
xmongoosex@hotmail.com
you should take your cylinders off and wash out the whole engine, crankcase and all, in case any metal is still in there. I would also like to know where the chunk went!
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
