High compression piston for mojave?
Old Apr 25, 2000 | 10:49 PM
Mojave87's Avatar
My 87 mojave could use a little boost so i was looking around for some good mods. I thought of maby a high compression picton for my next mod what do you think. I already have a WB E-series pipe and k&n air filter but was forced to put my stock pipe back on by the police the wb was too loud. so what do you think i should do next to my mojave?
I was also thinking of putting some black maier plastic on it. what does everybody think of the maier plastic?
Thanks
Ryan
Old Apr 26, 2000 | 12:08 AM
JD250R's Avatar
Go with the 11.5:1 Wiseco piston. DON'T buy the Maier plastic, I have black race plastic and a yellow nose piece on my 87 Mojave and it is JUNK. Don't waste your money on Maier! IT SUCKS! Buy factory Kawie plastic. Is cheaper and a lot better quailty!
Old Apr 26, 2000 | 11:16 AM
Jeffksf's Avatar
I have the 11.5:1 Wiseco along with head porting and black box mod and Supertrapp IDS. I did this all at once so I can't say what just the piston did alone but all this made a huge difference. Explain what the cops did, I can't believe they didn't just impound it and give you a ticket. I second the thought about Maijer plastic.
Old Apr 26, 2000 | 01:01 PM
depakote's Avatar
Hey JeffKSF,
If you had to put a dollar amount to what you did how much would that be? Can you list what you did to your engine. I would like to break into mine but really don't have any guidance. What size jet are you running?
Thanks,
Old Apr 26, 2000 | 03:13 PM
garyc400ex's Avatar
The Mojave already has 11/1 compression. Assuming 2 engines in good working order, you could not tell the difference between the 11/1 motor and the 11.5/1 motor. If you went with 12/1, there will be a small difference, but you will loose some reliability. If Mojave87 means you ride a '87 model Mojave, then a rebuild may be in order to regain lost performance.
Old Apr 27, 2000 | 04:18 PM
Mxracer98's Avatar
Do you know where you can get a 12:1 piston for the mojave.
Old Apr 27, 2000 | 04:52 PM
JD250R's Avatar
I believe Wiseco makes a 12:1 piston, but you'll have to run race gas.
Old Apr 30, 2000 | 06:40 PM
Jeffksf's Avatar
Depakota, I spent less then $700 I also needed 2 new valves because 2 of mine were beyond grinding those were $78. Not every motor would need new valves though. I'm running 140 main jet. I sent my head to Four Stroke Tech for the porting and valve job $200. They also modified my black box to remove the rev limiter $80. The piston was $100 with gaskets and $35 to bore the cyl. I had that done locally. I also bought my exhaust and jet from FST. Be advised most engine builders are always busy, don't expect a 2 week turn around. FST had my head for 2.5 months. I also run 50/50 mix of 93/110 octane gas. I'm also running 14 discs in my supertrapp.
manuelrivera
Aug 8, 2015 04:34 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
