For all of you that own a rancher ES
Old Apr 26, 2000 | 12:55 PM
ibcamiii's Avatar
Have any of you noticed a delayed shift when you press the up or down bottom...like when you press it does it take a few seconds before it gears up or down, or does it happen immediatley???????????
Old Apr 26, 2000 | 02:28 PM
LarryK's Avatar
I have not had a shifting problem at all. When it shifts it shifts right now. I had a bad alignment problem that the dealer corrected and gave me a new set of front tires. I also noticed my pipe coming right out of the head was glowing bright orange at night. I contacted Honda headquarters in CA just to double check my dealer(he said it all checked out ok)Honda says they are using a lighter stainless tube and its normal. The spark plug looks good and the valves are properly adjusted and its not running lean. I suppose I have to believe them. I have a 2 year extended war. so I'll see! As far as your shifting I would get it back to the dealer soon as possible.
Old Apr 26, 2000 | 02:30 PM
snowshark's Avatar
No delay when upshifting or downshifting, take it to the dealer & have them check it out.
Old Apr 26, 2000 | 11:39 PM
Galt's Avatar
I have not had any shifting problems. It shifts as fast as the foot shift quads that I have ridden. In fact, at times I powershift mine and found that it is a lot quicker that way. I was a little worried about damaging it, but one of the reviews I read before I bought it said that when Honda gave them the bike to test that they told them to ride it like that. NO problems at all so far. If yours is slow to shift, it has a problem. Get it to the shop ASAP. Good Luck.
Old Apr 27, 2000 | 03:30 AM
dirtyhowies's Avatar
On the 450 es there is a clutch adjustment. On the 450es there is a screw locknut on the bottom of the motor where you would loosen the lock nut and turn the screw counterclockwise till you feel it bottom out then back off 1/4 turn and tighten lock nut to 15lbs. THIS IS ONLY FOR THE 450es the rancher could be different. Hope this helps
Old May 1, 2000 | 12:44 PM
tempest's Avatar
I haven't noticed a pause while driving however if the quad is not moving and I shift down to Neutral there is sometimes a short pause.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
