Problems with 03 Blaster........
Old Apr 14, 2003 | 06:19 PM
00YaBlaster's Avatar
Default Problems with 03 Blaster........
Lately when ever I gun it...it hesitates for like 3 or 4 seconds then takes off. This happens alot. Also there is this tube hangin off the carb and gas or oil or both is leakin out of it at a large rate. any ideas? TIA
Old Apr 14, 2003 | 06:39 PM
WarriorMan05's Avatar
The leaking out of the tubes could be that the float is stuck or something like that. Mine did that and I just took the carb off and cleaned it, and it worked just fine.
Josh
Old Apr 14, 2003 | 06:41 PM
Could I just bring it in to the dealer and make them fix it? I mean would it be covered by the 6 month warrany. Also any instructions on removing the carb?
Old Apr 14, 2003 | 10:10 PM
you could take it to the dealership sure, but you arent always gonna have that warranty, and im pretty sure that you arent gonna wanna pay their prices for basic stuff like that.
To take the carb off, you first turn off the gas, and run it until it dies, so that the carb is empty. You then unscrew the two bands on either side of it. Next unhook, on the left, the fuel line, and on the right, a very thin black tube, the oil injection tube. there are a couple orange lines coming out the bottom, dont worry about them, they stay on. Next, unscrew the little side clip that unscrew the top of the carb. Be careful not to loose any pieces out of it. The carb shoudl then be free.
Turn it over, and there should be four little screws. Unscrew these, and take that cover off. look to see if there is any sediment, or anything blocking the floats.
Hope this helps
Josh
Old Apr 14, 2003 | 10:14 PM
Thanks a bunch Josh...your a life saver. BTW I was only gonna bring it to the dealer if the warranty would cover it. BTW I went back out after about a gallon of fuel leaked out. Started it right up and it ran almost perfectly....hesitated once.
Old Apr 15, 2003 | 07:38 PM
No problem, glad I could be of some help.
Josh
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
