99 Big Bear starting problems
Old Apr 26, 2000 | 08:51 PM
jhanna600's Avatar
The 99 big bear 2wd has problems starting. It is not the bartteri because i already tried that. So I am wondering what that problem is and if i can fix it?
Old Apr 26, 2000 | 11:37 PM
YJW's Avatar
YJW
A little more info would help. Does it roll over normally but doesn't start or is the problem with the electric start?
Old Apr 27, 2000 | 09:41 AM
gunnerm's Avatar
I had the same problem on my 98 BBSE and it was the actual connections inside the electric start handle bar switch. Dirt and other assorted crud got inside there and the connections weren't making good contact. If you tried to push the starter button it wouldn't go all the way in ... and even when it did the bike still wouldn't turn over. Checked battery connections, battery, solenoid etc. and finally tracked it down to this. A good cleaning with "contact cleaner" and it hasn't acted up since. Maybe check this out and see ... I thought that this was too easy to be the fix, but it was.
Good luck.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
buckshit
Sep 24, 2015 08:49 PM
Bulls
Jun 7, 2015 12:55 PM
volsgo30
Jun 4, 2015 06:07 PM
1000gade
May 27, 2015 12:37 PM
