needles
Old Apr 20, 2003 | 03:17 AM
justanotherRAPTOR's Avatar
Default needles
clip is in stock......3rd spot. if i drop it down a notch it will richen......correct? my plug on the right is too light for me. it is really light brown. not chocolate but really tan. plus it started "pinging" so i figured it was running way to lean.
Old Apr 20, 2003 | 03:36 AM
THEMOOSE's Avatar
Default needles
Yes that will richen it but if your looking at the ceramic on the plug & are looking at it after it's been idling your reading your plug wrong.
You need to do a plug chop with a new plug & look at the base of the threads instead of the creamic.
Here's how you do it (from the Trinity Racing web site)
TO READ PLUGS PROPERLY YOU WILL NEED A 10x ILLUMINATED MAGNIFYING GLASS
1,2,3. This is how it's done!
1. You set your heat range from the ground strap. (this is the piece closest to the piston)
2. You do all the plug readings for jetting from the base ring (thebase ring is what the ground strap is welded to at the end of the threads)
3. You determine detonation and timing issues from the porcelain.
(The porcelain shows preignition/detonation, it will not accurately determine jetting / air/fuel ratios)
DO NOT BASE JETTING DECISIONS ON THE PORCELAIN COLOR.
1. How to determining plug heat range:
The ground strap is your window to getting this right. If the "color" of the ground strap "changes" too-close to the ground-strap's end, (the end opposite of the base ring), then the heat-range is "too-cold", (heat transfer is to quick to the base ring)
If the "color" of the strap changes near where it is welded to the base-ring, then it means that the plug heat-range is "too-hot", (heat transfer to the base ring is to slow causing the deposits to be burned off the strap completely) The strap at this point could start working like a "glow-plug", probably resulting in pre-ignition/and/or detonation. The properly set heat-range is when the "color" is at the half-way point on the strap.
2. Reading the base ring to determine jetting:
The base ring "color" is very close to the color of the piston crown and is used to determine the jetting. Your looking for the soot color to be a nice light to medium brown, (color is always hard to describe) if the color doesn1t go all the way around the base ring (at least one full thread turn on the plug) or the color is whitish it is way too lean. If the color goes all the way around, but there is a spotting of heavy dry soot on the top of the color, you are too rich. ( TWO STROKE JETTING WILL BE A LITTLE WETTER LOOKING AND DARKER THEN A FOUR STROKE )
3. Read the porcelain to determine detonation / preignition:
The first signs of detonation / preignition will be seen on the porcelain down in the plug, It shows up as tiny black or shinny specks of aluminum. Also Look very close around the center electrode where the porcelain intersects, this will appear to be melting between the insulator and the electrode.
Detonation is caused by the air/fuel mixture exploding rather then burning. This gives off a sound, (a knock) this sound is the result of a shock wave, this wave disrupts the boundary layer of cooler gases that cover the internal parts of the combustion chamber. This causes a very rapid rise in pressure and temperature. The results are holes in the top or sides of the pistons, blown head gaskets, broken rods, (all bad stuff) This can also shock the rings from there seal causing oil to form as little spots on the porcelain.
save this for future use!!
Old Apr 20, 2003 | 01:43 PM
Default needles
thanks...... will go see what i can come up with
Old Apr 20, 2003 | 03:11 PM
RoostItUp's Avatar
Default needles
Wait, as in dropping it to the 4th or 2nd notch from the top? if you were to goto the 2nd it would lean it and the 4th would richen it.
Old Apr 20, 2003 | 04:46 PM
Default needles
ya i am dropping towards the tapper at the bottom. i dropped to the 4th and still too lean so i am going to the final and 5th.
Old Apr 20, 2003 | 04:53 PM
RoostItUp's Avatar
Default needles
Wow thats gettin pretty rich, mine really starts babbling when i got that low on the needle. Its still a little rich in the mid on the 3rd notch. What are you running? whats your carb set to?
Old Apr 21, 2003 | 12:43 AM
Default needles
this is for my shee. it is ported polished....fmf pipes....clamp on kn......290 jets. supposedly the carbs are aftermarket. i just put the clamp ons.....on. it had a uni w/ holes in the lid. i need to know where i can get JUST jets. i need some from 300-340.
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
