What 250 EX Tires?
Old Apr 24, 2003 | 11:09 AM
speedydog5's Avatar
Default What 250 EX Tires?
I want to get rid of the ballon tires what tires are you guys running, I don,t want to slow down at all, but I would like better handeling to keep it from being tippy and what size are you running, does any help out with better top speed or acceleration?[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 24, 2003 | 12:39 PM
DSAPP's Avatar
well... the only way you're not going to lose top speed, is to not go with a smaller tire...
but you are right, you need a less grippy, flatter tire....
does turf-tamers make a 22" tire..... or like Kenda Scorpions?
both of those slide alot better than the stockers....
don't go with Holeshot or Razors... they have way too much side bite for a little 4-stroke
look around... good luck
Old Apr 24, 2003 | 05:11 PM
ex400rdr's Avatar
My friend ran 20x10x9 bandits on his 250ex and they worked well for him, i also run those on my 400ex
Old Apr 29, 2003 | 11:36 PM
maxamillion's Avatar
what do u mean dont run razrs? i run them on mine and they hook up awesome, i recomend them to ne one. mine r 20-11-9, i didnt notive any loss in top speed but they also make a 22in tire.
01 250ex
pro circuit t4 full system
k&n air filter, outerwear, removed air box lid
DG alloy reinforced nerfs
DG alloy front bumper
20-11-9 razr rears
Old Apr 30, 2003 | 07:51 AM
Mike Chero's Avatar
maxamillion,
He was refering to the side bite for sliding, not straght ahead traction. That being said, stay away from the Razr2 rears. I went on a poker run last weekend on my 400EX and all it wanted to do was tip over. It had too much side bite to allow them to slide. The front Razr2s are great though. They tracked straight through the mud and gunk like dry pavement. Might I reccomend Holeshot XCRs (not XCTs) for the rears. They are designed for four strokes without a lot of horsepower.
Old Apr 30, 2003 | 09:39 PM
i thought u were talking about the regular razrs. thats what i have and i am able to slide pretty good with them. but i dont know about the razr2 tires.
Old Apr 30, 2003 | 11:44 PM
2000IAWarrior's Avatar
get all tracks for the rear and front pro or pro fronts w.e thy are called made by maxxis..
Old May 1, 2003 | 07:38 AM
Mike Chero's Avatar
Like I said, the Razr2s are "all that" as far as straight line traction. The lugs are a lot taller than the standard Razrs. On up hills I tried to feather the clutch to get some wheel spin and the RPMs up, no such luck! In the corners they seemed to stick like glue. I had a rough time sliding them even in the soft, loose stuff. Only when things got slick (i.e. hard, wet clay) would they finally slide.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
