Off idle stalling
Old Apr 27, 2003 | 08:13 PM
bigmackloud's Avatar
Default Off idle stalling
Hey,
on my '97 Warrior, if i'm idling along and then punch the gas it dies completely. but if i give it a little gas first, and then punch it, it doesn't stall.
i have a 150 main jet. air screw was 1.5 turns out. i tried 1 turn out and lowered the idle, but that didn't change anything.
might be related; if i run it hard and then come to a quick stop and let it idle, the idle remains high. is that a sign of leaness? if so, where at?
thanks,
bigmac
Old Apr 27, 2003 | 09:01 PM
sixsixT's Avatar
Yes that is a sign of being lean. Try turning your mix. screw out first 2 to 2 1/4 turns out.
Old Apr 27, 2003 | 09:24 PM
Hey,
i turned my air screw 2.5 turns out (total). it might be a little better, but the stall is still there. i guess i can try turning it a little more.
thanks,
bigmac
Old Apr 28, 2003 | 07:24 AM
raptor8's Avatar
idle/low = mixture screws
mid needles
high mains
they all work together
Old Apr 28, 2003 | 07:04 PM
Hey,
yea, i just need to determine which of those is the problem. if i'm just cruising around and tap it at 1/4 throttle it pulls pretty hard. but it's when i hit to 1/2 throttle or more that it dies. but when the rpms get higher, it runs ok.
maybe i'll try adjusting the needle.
also, the spark plug is two different colors. it's split right down the middle, one side is whitish, the other side is black. can aby body explain that one?
later,
bigmac
Old Apr 28, 2003 | 09:27 PM
sixsixT's Avatar
You need to raise the needle / lower the clip.
Old Apr 29, 2003 | 12:09 AM
Hey,
yea, i think you're right. the air screw didn't really do much for the stalling. so now i'm just working on how to get too the jet needle. gotta figure out how to take out the shaft that goes through the arm that lifts the slider.
thanks,
bigmac
franklyme
Oct 21, 2016 07:18 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
