Rancher choke
Old Apr 29, 2003 | 09:25 PM
Dirtpig's Avatar
Default Rancher choke
Anyone else having trouble with the choke on there Rancher? Mine is a 01 and is is really stiff ! just replaced it and it worked OK for a little while now it is really hard to pull again.............................any suggestions?
Old Apr 30, 2003 | 12:03 AM
RedRancher's Avatar
I had a similar experience with my 2001 Rancher where my choke grew stiff until it stopped working altogether. My problem was with the collar on the carb (where the choke cable goes into the carb) it let moister in. Because of this, a small amount of water entered in and around the collar restricting the movement of the entire choke system from within the carb. If you want to fix it yourself perform the follwing six steps:
a) remove old choke cable
b) get another choke cable
c) lube the new choke cable
d) lube the inside of the collar at the carb (where the choke cable enters the carb)
e) install new choke cable
f) work the choke back and forth to make sure the lube covers all surfaces inside the cable and in the choke collar at the carb.
Good Luck!
Old May 1, 2003 | 12:09 AM
cluby's Avatar
they have a new choke cable out that is better sealed at the top the other problem I see is the plunger get croued in the carb I put delectric grease on top of the choke plunger up where the cable comes in that has sloved the ones that I worked On good luck with yours
Johnny Mac
Aug 15, 2019 03:13 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
wrencher82
Sep 24, 2015 03:39 PM
