300ex Final drive gearing
Old Jan 21, 2000 | 10:59 AM
quad_300ex's Avatar
I have a 300ex and I don't know a lot about the gearing on a 300ex, but I would like to know what others has tried and what works the best?
Old Jan 21, 2000 | 08:18 PM
retromotoracer's Avatar
The stock gearing is 14/38 ,and if you haven't noticed, its a little to low.Try a 15 counter shaft (front) sprocket if you want higher gearing. You will lose a little take off but not a lot.The sprocket will cost about $15.00 and should give you a noticible increase on top end.
Old Jan 21, 2000 | 08:29 PM
quad_300ex's Avatar
WHat about the case saver? do I have to remove it ?
Old Jan 22, 2000 | 01:27 AM
jarniet's Avatar
actually I'm pretty sure thats a 13 tooth front sprocket standard. you may want to check a shop manual or something first. just dont want someone spending 15 bucks uselessley
Old Jan 22, 2000 | 01:36 AM
RangerSX's Avatar
Well to fill you all in the stock countershaft sprocket is 13 tooth, so if you put a 14 tooth front on you will get a higher top speed and wont lose any on low end.
RangerSX 1987 Honda 250X(completely stock)
Old Jan 22, 2000 | 04:31 PM
quad_300ex's Avatar
Thanks you all, But what about the rear spocket do I need to chnage the size of it to?
Old Jan 22, 2000 | 08:37 PM
RangerSX's Avatar
you dont really have to go smaller, but if you want more top end you could go down a couple teeth in the rear. you cant fit any bigger front sprocket on.
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
