300ex Final drive gearing
The stock gearing is 14/38 ,and if you haven't noticed, its a little to low.Try a 15 counter shaft (front) sprocket if you want higher gearing. You will lose a little take off but not a lot.The sprocket will cost about $15.00 and should give you a noticible increase on top end.
Well to fill you all in the stock countershaft sprocket is 13 tooth, so if you put a 14 tooth front on you will get a higher top speed and wont lose any on low end.
RangerSX 1987 Honda 250X(completely stock)
KimSJoh
14
Jul 18, 2015 07:20 PM
