Parking Brake Block Off Problem
Old May 6, 2003 | 01:07 PM
BuckinHO's Avatar
Default Parking Brake Block Off Problem
On My Warrior I removed the parking brake crap and put on an ac block off on the rear caliper the problem is It keeps leaking brake fluid I have tried many rtv type gasket reapariers and I have made gaskets. The stock gasket has to big of center whole to use it. Any help would be great cause I am getting sick of redoing it over and over.. So Thanks In advance.........[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 6, 2003 | 01:30 PM
BuckinHO's Avatar
Should there be brake fluid in there. Or is there certain stuff you should use to seel it.
Old May 6, 2003 | 01:58 PM
THEMOOSE's Avatar
It sounds like you need to rebuild the caliper, fluid is leaking past the seals on the piston.
It has nothing to do with the parking brake block off unless dirt has entered & caused the damage to the o-rings.
It's not a difficult repair, you just need to make sure there are no deep scratches in the bore.
Old May 6, 2003 | 02:07 PM
BuckinHO's Avatar
Do they Make Rebuild Kits For it. Or do I have to order the parts individually
Old May 6, 2003 | 02:19 PM
THEMOOSE's Avatar
I've never checked on that but I'm sure your dealer or many online stores can get you what you need.
Old May 6, 2003 | 02:36 PM
bigmackloud's Avatar
Hey,
now you've got me a little worried. my rear brake is leaking fluid around the rubber seal thing on the end of the parking brake. my plan to fix this was to order a block off plate tonight. but now i'm worried that's not going to solve my problem.
so who sells a caliper rebuild kit and how $$$ is it?
thanks,
bigmac
Old May 6, 2003 | 03:05 PM
THEMOOSE's Avatar
I looked at my parts & price list & the seal kit for a Raptor (which should be similar to a warrior) was $7.07 for the 2 o-rings. that looks to be the only thing needed unless your piston is scored.
Old May 7, 2003 | 07:43 PM
BuckinHO's Avatar
Hey Guys Thanks I went to a local store that sold Metric Orings Replaced the rear one of the caliper works excellent. Thank You. .36 Cent Fix. Its nice to get away with that once in a while.....[img]i/expressions/face-icon-small-smile.gif[/img]
skinnyr6
Aug 25, 2023 02:18 AM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
