HELP! PRAIRIE 650 TRANNY??
Old May 11, 2003 | 03:45 PM
biggun650's Avatar
Default HELP! PRAIRIE 650 TRANNY??
Guys,
I need some help. My 2002 650 works just fine, except when I put it into low range. When I do this it goes in just fine, but when I get on the gas and let off it grinds and gets kicked in and out of gear. When this happens it is a horrific sound coming from my baby. Has this happened to any of you and if so what should I do?
Thanks,
Jay
Old May 11, 2003 | 05:42 PM
kawlaris's Avatar
Your shifter needs to be adjusted. When the shifter is in the low position the tranny is not quite all the way in low. To test this you can go down a hill or let off the throttle, while forcing your shifter in the lowest most position. To fix it your shifter linkage rod needs to be adjusted shorter.
Old May 11, 2003 | 07:11 PM
Andy~G's Avatar
Yep your shifter need an adjustment.
Remove the tank plastic and look at the shift rod that connects to the bottom of the shifter.
Loosen the nut and shorten the rod so that it pull the transmission farther into low.
Its real easy to do.
Andy
Old May 11, 2003 | 09:20 PM
roscoe69's Avatar
Biggun650
Yes knew the feeling well , have tried to adjust mine about 10 times, 4 on saturday. Getting ready for long weakend next weekend. Sounds like its going to tear the heart out of tranny. Got tired of adjusting it and said screw it, it will still have more power in high range then all of the machine's that are going to be there except alltoys. I would sure like to adjust it and get it right. I put a new belt on it so it has a slight squeel for now but idles down to 10 klicks per hour no problem. Will work on it some more at a later date.
Old May 11, 2003 | 11:23 PM
destand33's Avatar
my friend was having the same trouble and he was running the same size tires all the way around 27-10-12 he had to by 27-12-12 for the back. fixed the prob, never did it again.
Old May 12, 2003 | 08:22 PM
Ginchy's Avatar
it is easy to adjust, start the bike and with it running adjust the shifter by making it shorter, adjust it in neutral. fool around with it and youll catch on to what you want to do
Old May 13, 2003 | 12:58 AM
partsman2's Avatar
I think Nyroc's website addresses this issue and has instructions on how to adjust. This is a common problem and is relatively easy to fix compared to how bad the problem sounds. This is a very fine adjustment so don't over do it.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
