piping the blaster
Old May 13, 2003 | 10:25 PM
crispy's Avatar
Default piping the blaster
hey,
which pipe should i use to make my blaster faster? wich is a good choice?
also, will a change in the front sproket make a big difference in speed?
blasterrida
Old May 13, 2003 | 10:43 PM
MojaveRider250's Avatar
I heard toomey was the best and my friend got one and it sounds awesome. and the change in the sprocket will change a speed diff if u go up in teeth u will go faster.
Old May 13, 2003 | 10:47 PM
PmanX8's Avatar
Your best bet is the Toomey B-1 kit. it produces the best overall power increase over all the other pipes, plus comes with the pipe, Silencer, high Flow air filter, 310 main Jet and a cross-bar pad. www.rockymountainatv.com has it for 299.99 that is unbeatable for the performance and price[img]i/expressions/face-icon-small-smile.gif[/img]. and yes if you go a tooth up on the front sprocket, you will have a bit more top end speed, but you will lose a little low end tho. but after the pipe kit, both low end and top end are greatly increased, good luck.
Old May 14, 2003 | 06:15 PM
crispy's Avatar
if i put a jet kit on the blaster, do i have to replace the exhaust with something other than stock. can i just keep the stock exhaust and put a jet kit on it and have improved power. i'd like to just put a jet kit on it, how much power/performance more will that give me? will it be noticable and worth it. and i don't have to have any other fuels or anything for it do i? just put it on there and run it like i normally would?
help appreciated
blaster rida
Old May 14, 2003 | 07:35 PM
yfsrider's Avatar
perfect jetting will help increase hp, not by much, i went with the b-1 and i LOVE it. you wont be dissappointed
Old May 15, 2003 | 12:59 AM
PmanX8's Avatar
help appreciated
blaster rida
If you want to up the power a bit but dont want to get the after market pipe on there, than you could get a "Power kit".
it consists of a high Flow Air filter, a complete Dyno-Jet kit and a filter care kit along with outerware's.
there around 99 to 130$ depending on what kit you get. the K&N kit is a good one. the filter/jetting combo will give you noticable power increase plus the engine will breathe better too.
Old May 15, 2003 | 01:01 AM
YFZRacer's Avatar
i would suggest if you have the money to go with the toomey kit it will make a good gain in power and be a lot more noticable then just the jets and air filter
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
nastyblaster100
Sep 13, 2015 01:19 PM
