piping the blaster
Your best bet is the Toomey B-1 kit. it produces the best overall power increase over all the other pipes, plus comes with the pipe, Silencer, high Flow air filter, 310 main Jet and a cross-bar pad. www.rockymountainatv.com has it for 299.99 that is unbeatable for the performance and price[img]i/expressions/face-icon-small-smile.gif[/img]. and yes if you go a tooth up on the front sprocket, you will have a bit more top end speed, but you will lose a little low end tho. but after the pipe kit, both low end and top end are greatly increased, good luck.
if i put a jet kit on the blaster, do i have to replace the exhaust with something other than stock. can i just keep the stock exhaust and put a jet kit on it and have improved power. i'd like to just put a jet kit on it, how much power/performance more will that give me? will it be noticable and worth it. and i don't have to have any other fuels or anything for it do i? just put it on there and run it like i normally would?
help appreciated
blaster rida
help appreciated
blaster rida
help appreciated
blaster rida
help appreciated
blaster rida
it consists of a high Flow Air filter, a complete Dyno-Jet kit and a filter care kit along with outerware's.
there around 99 to 130$ depending on what kit you get. the K&N kit is a good one. the filter/jetting combo will give you noticable power increase plus the engine will breathe better too.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
