What do you think? Jetting...
What problem are you trying to solve by going down to a 142 ?
Going down on the main will lean things out when you are WOT. If you're already good at WOT then you may not need to go down, you may just have to mess with the needle or else pilot/idle circuit.
The surge could be a lean surge...not good.
Watch the plugs and piston wash......
What do the plugs look like after a WOT run ?
-jeff b.
-jeff b.
rule of thumb on jetting. if your asking for throttle and it acts up, your lean. if your not asking for throttle and it acts up, your rich. i wrestled with my 250ex for days over this. are you sure your not redlining and hitting the rev limiter? rejetting will get you there (rev limiter) much faster than stock and it takes some getting use to. a good symptom of running rich is if sounds like its loading up or flooding on idle, the pipe will give off a black, almost wet smoke.
voodoo on the Dynojet troubleshooting Guide says 1) check you float level, mine is 7/10 of a inch or 44.8/64 of a inch. 2) It says lower the needle down.( you would think the needle should go up) 3)if that don't work, then it says put even a smaller jet in.
It's worth a try.
It's worth a try.
Voodoo- I am sure you already know this but start over with a new plug and clean the air cleaner. A fouled plug will make you think you are having carb problems. If you are still rich, take your airbox lid off and ride it. If it gets better you are rich and need to go to smaller main jet. With your airbox back on and it starts to cut out at mid to WOT, turn on your choke and see what happens, if it runs better choked , it is too lean.
Jetting can be a P.I.T.A.
R00ST
10-10-2004 10:30 PM
