cat wont warenty
Old May 13, 2000 | 12:11 AM
myway351's Avatar
hi guys just thought i let you know how the steering colume work out. well took it to my dealer to have warentd and they said no prolblem but one weak later i go to pick it up and they said it wasnt covered. i look at the guy and said what are you crazy the thing is two months old
and only 160 miles. they said that these type of things dont break and there for you must have missed used it. so that wasnt good enuff for me so i called cat directly. and they told me my best source was my dealer. so i told them what my dealer said. well aferter about an hour and half i finnly got it warentd what a pain.
so good luck to you guys and hope you have better luck than see on the trail if ride hard play slow
wiggy150
cat 500 stander
Old May 13, 2000 | 09:23 PM
cowboy's Avatar
Myway351:
Glad to hear you were finally able to get your steering column warranteed. While I can understand their point of view that the welds shouldn't break unless it's because of miss-use, a good weld should still be as strong, if not stronger than the actual steel tubing itself, so it sounds like they just had a bad day at the shop when building your bike. As for the dealer, I haven't met a dealer yet who actually was willing to work on a defect under warranty without complaining about it. I'm sorry to hear you had so much trouble getting through to them, but at least they took care of it. Glad to hear you finally got it fixed.
Happy trails!
Mike
Old May 14, 2000 | 07:17 PM
BONER's Avatar
Myway351:
Whats that #?
I will be chewing out some one there for sure.
My 500 just lost most of it's power to the rear wheels. They seem to be pulling some times but other times the fronts spin and there is a noise like gears striping coming from the engine and the rears don't spin.
I am looking in my 1999 model service manual and it says this:
"Rear axle shaft serration worn--broken"
remedy= "Replace shaft"
This REALY SUCKS cause:
1. I just save up enought money to order my warn 2500 winch(was gonna order it monday) and now I will either be spending it on the repairs or selling the bike.
2. I will start my job june 1st and I NEED my cat for transportation since I have not automobile and no licence.
Old May 15, 2000 | 08:00 AM
zrt1000's Avatar
I had this problem on my 454, (and my buddy too )It is the bearing on the rear shaft It holds the two splines together when the bearing goes bad they slip it is not hard to fix I think it cost me about $100 to do it myself ... Take it apart and you will see..
Bulfrog23
Dec 6, 2009 08:08 PM
warhorse20000
Jul 30, 2008 12:32 AM
jetmotoracer
May 28, 2007 10:16 PM
LaPurr
Sep 30, 2006 04:56 PM
MRBIGSHOT
Mar 28, 2003 11:18 AM
