attention carb experts
Old Jul 10, 2003 | 11:49 PM
CatsMeow's Avatar
Default attention carb experts
i finished my snorkel and pipe mod and i think i am a little bit rich on the mix. at first it ran good and the plug was a little black. now it is a little blacker. today i took the airbox lid off and it ran great through all the gears, no popping or anything. with the lid on i have some surging at steady thottle and cutting out while increasing throttle. should i: adjust needle, use smaller jet, play with supertrapp discs, float adjustment?
Old Jul 11, 2003 | 01:42 PM
Bigcat's Avatar
CatsMeow
You are running out of air, problem is at the carb..... I will try the needle first, try going up 2 notches (5-3) or go down 1 size jet and the float adjustment height is 17mm or 0.7 inch, or 44.8/64th inch or maybe make the pipe for the snorkel bigger in diameter.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Ranger_Rod
Jul 15, 2015 07:08 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
