Rear Brake problem
Old Jul 15, 2003 | 08:42 PM
Anton's Avatar
Default Rear Brake problem
I was out yesterday and lost my brakes and fluid? I limped it to a gas station put some fluid in, and started to look for a leak, didn't see any. Bled the system just in case, started home with no brakes, they came on after a couple of quick stops [img]i/expressions/face-icon-small-confused.gif[/img] then gone again?
Got home and had someone pull on the handle while I looked.......... saw fluid coming out of between the pads in calliper???????????? Today I took it apart and to my surprise the rear brake pads are gone all that is left is metal plates one of them has been worn to all most zipo.
Ok so question is
Would the calliper be ok. Is it safe to assume that it was pushed out so fare as to allow fluid by? And all I need are the pads?[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jul 17, 2003 | 04:03 PM
vhcat400i's Avatar
I had the same prob.As long as the piston isn't damaged you should be fine just replacing the pads.Make sure you check the front pads as they may need replacing as well.
Old Jul 17, 2003 | 05:27 PM
Anton's Avatar
Ya I hope so. thanks for your reply. I went to my dealer and ordered the pads. Do you know what they are going for............$19.00 Canadian per pad. what do my US friends pay?[img]i/expressions/face-icon-small-shocked.gif[/img] That would be $40.00 x 3, gst,pst......HOLY HANNA. Hoping to be on the trails by this weekend.
Was out by my self so I am the only witness, and hit a small pile on stone, popped it up and did a nice cat walk. Thats with a 03 400i. I didn't know it would do it, I was holding on because it was so unexpected. But I went back and did it again, & again & again................
Thanks for your help and I will let you know if it works out
Old Jul 19, 2003 | 03:07 PM
vhcat400i's Avatar
The cost of mine in NY was $13.00 a pad.They definetly are not cheap but something you need.
Old Jul 22, 2003 | 11:54 PM
Othic's Avatar
The same thing happened to mine. Is it safe to put Dot 3 in it instead of Dot 4 ?
Old Jul 23, 2003 | 02:14 PM
vhcat400i's Avatar
Yes.That is what I used.
Old Jul 23, 2003 | 03:43 PM
voodoo's Avatar
Anton, i bought my replacements from royal. Its more like 25 per pair from them... They last just as long as the ones from Cat.
Old Jul 24, 2003 | 06:02 PM
Anton's Avatar
Hi Voodoo
Thanks for the tip, I went to there web page and yap, $25.00 bucks a pare.
I took a good look at the fronts and I will need to change them also. I also order a catalogue, off there web page just to keep as a reminder[img]i/expressions/face-icon-small-smile.gif[/img] Thanks again
Old Jul 24, 2003 | 07:19 PM
voodoo's Avatar
NP hope that they last a bit... but at 40 bux a side plus tax a fella has to try other things...
AK47KID
Jul 23, 2015 09:21 PM
rcappie4
Jun 21, 2015 07:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
