HELP!!! my quad won't run
Old Nov 18, 2003 | 01:10 AM
mudcatsick250's Avatar
Default HELP!!! my quad won't run
I have a 2000 arctic cat 250 and it won't start, the batery was new this spring and i charged it and it wasn't that,its getting good spark and is getting fuel. i'm stumped
a little help would be much apreciated.
Old Nov 18, 2003 | 11:51 AM
memento's Avatar
You know for sure that it's getting fuel and a spark? It should run then. Maybe not good, but that should really be enough to get it started. I have a VW beetle (1974) that I'm having the same trouble with, but I have no way to confirm if it's getting a spark.
Do you have compression? Does the engine turn over (but not fire) when you press start? Did you check the spark plug? Did a mouse make a home in the air filter?
Old Nov 18, 2003 | 04:51 PM
it gets spark, gets fuel, turns over okay, and has compression, this is why i am so confused
Old Nov 18, 2003 | 05:43 PM
akfireman's Avatar
maybe your getting too much fuel/flooding it, or not enough fuel/to lean. try using starting fluid and see if it fires like that, then you know its a fuel problem.
Old Nov 18, 2003 | 07:29 PM
CR724's Avatar
I had a mouse make a snack out my stator wires once. Bike would turn over, but no start.
Old Nov 18, 2003 | 09:16 PM
Polaris500HO4x4's Avatar
ok this is the best way to see if everything is right in your engine or not,, take out the plug and shoot some ether in the piston and put the plug back in if it fires or turns over you know you have spark and compression
Old Nov 18, 2003 | 10:28 PM
thanks a lot guys, got it runnin good, it was gettin fuel but not enough, so she was runnin a little lean
thanks again for all the help[img]i/expressions/face-icon-small-happy.gif[/img]
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
