valve adjustment
Old Dec 10, 2003 | 06:37 PM
35dodge's Avatar
Default valve adjustment
Am getting ready to adjust the valves on my 2001 500 man and I have a question about finding top dead center. The inspection hole for the timing mark seems to be underneath the exhaust pipe so that you cannot get the plug out, let alone see in to find the mark. Has anyone else had this problem, and if so how do you find tdc, I do not want to have to remove the pipe to access the mark. Thanks for any help.
Old Dec 11, 2003 | 11:55 PM
TORK's Avatar
I don't worry about TDC, turn engine over till intake valves are fully open and adjust exhaust valves, then turn over till ex are fully open and adjust in. When one set is fully open you know the other is closed and can be adjusted.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
