650 black spring
Old Jan 27, 2004 | 10:27 PM
650CATMAN's Avatar
Default 650 black spring
just to let anyone getting a black spring for your 650 through epi order the kawi black spring the web
site has an a/c spring but its not the same im a new member and just bought my 650 3 weeks ago
(sold my vinson 500)
Old Jan 28, 2004 | 01:14 PM
AC650's Avatar
Where did you purchase your black spring? I just purchased my 650 about a month ago and I am not satified with the engine braking. I have been told that the black spring will help with that.
Old Jan 28, 2004 | 08:37 PM
Wires's Avatar
I put in the black spring (and tightened the belt, since it was majorly loose).
The combination has been amazing! Engine braking before was non-existant in high. Now, braking in high is the same as low was before, and low is, wow! It reminds me of a sled!
Old Jan 28, 2004 | 09:02 PM
AC650's Avatar
When you changed the spring did you have to do anything else to the clutch (change pin weight or something)? I am not all that familiar with this issue that is why I am asking.
Old Jan 28, 2004 | 09:04 PM
eiger2's Avatar
Did you only do the Spring? How bout shims?
Wher did you get it? How much?Text
Old Jan 29, 2004 | 01:14 AM
650CATMAN's Avatar
i called epi and i talked to a tech and he said he has installed hundreds of them and he all ways
leaves all the shims or shim in just check the belt deflection (to do that lay a straight edge over
both pullys and give 13 pounds of down force on belt and it should only move 1 inch to 7/8 of an inch
any tighter and it will cause too muth wear i left my .12 inch shim in and it was perfect as for epi
they are bases out of bakster mn and and i think there web site is www.erlandsonperformace.com
go to kawi 650 the a/c will only give you the same spring you already have
i really havant had a chance to really test it out but its only been -5 and -30 windchill a little cold for me
but guy in new richmound e-mail i got a heated shop i have lots of atvs here bring yours by and
we'll put that spring in its $25.00 and it takes 2 days to get
the reason y i replaced mine was my belt light came on at 2 miles on my machine and i did a little
research on the sobject it went into limp mode that wound have sucked if i was not in my back yard
maybe i shoudnt have raced my bros p700 i did get him out of the hole and that was it i guess thats
what you get when you only have 2 miles on!
Old Jan 29, 2004 | 02:23 AM
Wires's Avatar
You just need to pull shims if the belt is loose (in my case, I needed to pull out the thin shim). I bought the spring from Dalton Industries (in Nova Scotia I believe). I think it was $40 CND to my door (maybe $60). EPI and Dalton make a similar product for a similar price. UPS kills us when we ship stuff from the US to Canada, so that's why I did Dalton instead.
AC650:
You don't need to tough the weights or anything. That's in the primary clutch, and the black spring goes in the secondary clutch.
Old Jan 30, 2004 | 07:08 PM
CR724's Avatar
Check the Kawasaki forum. There was a thread that had pictures of how to change the spring out.
'04 400i 4x4
Old Jan 30, 2004 | 08:17 PM
Wires's Avatar
http://www.atvpower.com/folders/tech...adjustment.htm
Has the info you need....
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
