Loose steering shaft ??
Old 03-03-2004, 11:22 PM
jwoodsman's Avatar
Default Loose steering shaft ??
I went out riding today and noticed some play in the handlebars the lower part of the shaft seem to be tight ,
when sitting still I can move the bars side to side and back and forward just a little ,It seem to have play in the upper column mount ,The upper mount bolts are also tight , Is this normal or am I just being paranoid ?
I still only have 202 miles ,so she's still new to me .
Old 03-03-2004, 11:25 PM
madcat17's Avatar
i have an '03 500 and it's the same way.
Old 03-03-2004, 11:53 PM
truckerhead's Avatar
My 04 650 with 128 miles is the same way. [img]i/expressions/face-icon-small-happy.gif[/img]
Old 03-04-2004, 03:05 AM
Redcruiser500AC's Avatar
My 04 500 does the same 67 miles on it so far.
Old 03-04-2004, 11:39 AM
CR724's Avatar
My 04 400i manual is the same way. Is there an echo in here????
Old 03-04-2004, 12:11 PM
ricerocket's Avatar
are the tie rod ends loose
Old 03-04-2004, 02:42 PM
gltco's Avatar
It is very normal unfortunately. There is a two part plastic bushing inside the upper column support. It wears very quickly and allows for quite a bit of movement . Once you get used to it you are ok. Safety wise it is not a big deal as the column is well supported but it does make it a little more difficult to detect loose or worn tie rod ends and ball joints which are real safety concerns.
Old 03-04-2004, 10:07 PM
jwoodsman's Avatar
Thanks for the quick response ,This is my first quad that took 33 years to get so any noise or looseness will get a quick repair . well as long as it's normal ,I can live with that .
Old 03-07-2004, 11:45 PM
Cub's Avatar
Cub
Cub is offline
yeah they all seem to do this! grease will hep extend life some. The p/n from Arctic Cat is 0405-020 and they are only $1.29.
Old 03-09-2004, 08:02 PM
CatKrazy's Avatar
yep thats right just deal with it..its the nature of the beast
Quick Reply: Loose steering shaft ??
