My new Cat is backfiring and .....
My Cat Auto has this annoying backfire.If I run full throttle and let off on the throttle as the rpm's drop it will backfire,sometimes loudy with a beautiful flame shooting out the pipe. Dealer has no friggin clue.
I was doing a little riding and hunting in Wyoming and South Dakota this week when I noticed that the brake fluid resovoir was leaking. The cap and screws were tight so I removed it cleaned it up and put it back on.Hopfully that will solve the leak.Anyone have something similar happen.
Mike
Mike
Mike- It is your jetting. Mine did the same thing to me on the backfiring. If it continues or it starts to smoke when you fire it up or when you press in on the throttle just adjust your jetting or take it to your dealer and let them. My 98 AC 454 still backfires after you build up RPM's and let off fast. Not all the time but if I have it ***** to the wall. Have you experienced the smoking?
Mine did the same but for a little while it got real bad and when you floored it it sometimes drowned out....i cleaned the carb and it fixed it right up...sometimes it backfires but seldum....i havent had any smoking proublms.....i have 1,700 miles now just rolled over....
fordfaithful21
Dec 7, 2015 05:52 PM
