need neutral safty switch help!
Hey guys I have the AC 300 4x4 99 model and was wondering if anyone has attemted and succeded in bypassing the neutral safety switch yet allowing it to start in any gear any help would be appreciated for this is a big pain. thx jeff
You might try this. These instructions are for the Suzuki King Quad and they have the same engine so I presume the same electrical also.
1. Find the neutral relay. (usually near the battery)
2. Connect the Y/G and Y/B wires together. (use a wire nut) Leave enough wire from the relay to reconnect if needed.
This should do it, and all the instrument lights should still work.
Njrider1230
Jul 29, 2023 05:16 AM
