reverse override
Old Aug 4, 2004 | 05:09 PM
finadic's Avatar
Default reverse override
Is there any sort of fix to override that override button on a 04 650.
Old Aug 4, 2004 | 08:53 PM
ng's Avatar
ng
I'm just gonna throw this out there but couldn't you just splice the wires going to the overide switch?I don't know if this would cause any other problems.Good luck and let us know what you figure out.
Old Aug 5, 2004 | 12:21 AM
weez440's Avatar
get a dynatek cdi not that i would but i could probably go about 60 mph in reverse without hitting the override switch plus it takes care of that pesky limp mode and gains ya some horsepower
Old Sep 4, 2004 | 04:33 AM
Rattlebars's Avatar
Dunno if the wires are the same color, but I put a toggle switch on my Kawa 650.
Check the wire colors at the override button and find them farther down the harness. Bridge them with a switch.... this does not hurt the belt sensor at all, but you can do reverse wheelies in FWD so...
You can see how I did in on the Kawa 650 which may or may not help ya.... check the link below....
Chet's Prarie Pages....
To just see a pic which explains it...... Pic of wires to bridge...
Old Sep 4, 2004 | 11:50 AM
limrok's Avatar
Hi...junplug the wire from the tranny on the left side.it isa single prong 90 degree .............and it is off all the time then.....i know it can bea bitch when stuck and need to use rev.and it runns like in limp mode.....i unplugged it and left it unplugged......that way if u need to take it to the shop....just plau it back in
.......RIDE HARD.....RIDE SAFE................AND HAVE AFUN....................
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
