help with arctic cat shifter???
Old Aug 5, 2004 | 01:21 PM
jaxBIGCAT's Avatar
Default help with arctic cat shifter???
I am looking for a way to replace the "heel to toe " shifter on my 2003 arctic cat 400. There is nothing available from arctic cat for models after 2002. I know these have suzuki engines, what i dont know is if the suzuki toe shifters would work. If anyone has tried to make the "toeshift" conversion. Any info would be appreciated. I would love to have a regular shifter on my bike.
Old Aug 5, 2004 | 02:37 PM
1wook's Avatar
You can cut cut off the heel portion and ben the toe portion so you can get your foot under it.
Old Aug 5, 2004 | 05:52 PM
Bear4570's Avatar
Then slide a rubber hose over the end of the lever to protect your shoe. Works good, did it for a friend who's to old to learn to shift different than the 100 Hondas he's owned.
Old Aug 5, 2004 | 07:03 PM
tta583's Avatar
Take a look, AC makes them for little $$$.
Go here:
Alpha Sports
Then paste this part number into the search box at the top of the page:
0436-239
I want to say my local dealer had them for about the same price. Worth a call so save a little shipping cost.
Brent
Old Aug 5, 2004 | 07:34 PM
Bear4570's Avatar
In some catalogs it says that toe shifter works on only thru 2002 cats, however I found one that says it works on the 2003's also and I know there was an engine change, but the tranny stayed the same so it should work.
Old Aug 7, 2004 | 04:33 AM
swampyjunior's Avatar
I have seen them for 2003 models as well. Don't remember where, but I seem to recall them being about $25.
Old Aug 9, 2004 | 09:44 PM
CatsRule's Avatar
I found the toe shifter on ebay. Its only $1.00
http://cgi.ebay.com/ebaymotors/ws/eB...category=43972
Old Aug 10, 2004 | 12:24 AM
Mudpuppy193's Avatar
jaxBIGCAT,
The toe shifter only works on the 02 and older 400s. You can either cut off the back part and reposition it a little so you can get a boot under it easily (I got size 15s so it wouldn't work for me anyway) or the 05 shifters come with the 2 piece shifter and all you have to do is remove a bolt or two and it converts into a toe shifter. I am not sure if the 04 to 05 shifter stuff is the same but I wouldn't see a reason why they would have to chnge it. That might be something to look into.....
Customer Service #1
May 15, 2020 08:46 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
