Questions about Hilifter ICM Power Pak
Old Oct 9, 2004 | 10:25 AM
turbocoupe's Avatar
Default Questions about Hilifter ICM Power Pak
i use the hl icm module i noticed it ran hotter but what i did was checked initial timing before the instalation well come to find out it adds roughly 10 degrees of advance which will make the machine run leaner causing it to run hotter i had to jet up 2 jet sizes front and rear but it was well worth the effort ive got 28 in titan 589s and from a idle if i blip the throttle it will stand on the rear bumper i also purchased the epi pro clutch kit for bigger tires after trying the pink and red primary along with the clutch weights i found that the p700 primary spring and the red epi secondary spring works real nice with big tires and with the icm module its totally awsum machine
Old Oct 9, 2004 | 10:29 AM
turbocoupe's Avatar
greencat what size snorkel did you put on such as inside diameter and lenth also how many jet sizes did you have to go up after doing the snorkel?
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
