shifting is difficult at times
Hey again everyone,
On my 05' 400i Auto, I find that shifting from hi to low, or hi to neutral, and reverse is really difficult sometimes. To the point that I have to smack the shift lever several times to get it to go into the new position. This cant be good for the linkage, or anything else...is there anything else I can do?
Might it have something to do with the fact that the dealer set the idle pretty high? He said the idle should be higher than normal during the break in period. The machine jumps a bit when it is put into forward or reverse. Is this to high? What should correct idle speed be, and how can I measure it?
Thanks
Thanks
Sometimes if you're on an incline and the tranny is in a bind you'll have to add a little force to get it to move. Not sure when when this is happening to you but this is something to consider. Does this happen when you're on perfectly flat ground as well?
KimSJoh
14
Jul 18, 2015 07:20 PM
