Where did you guys the carb heater kit for the 650"s
Old Feb 3, 2005 | 09:51 PM
DOGTRAINER's Avatar
Default Where did you guys the carb heater kit for the 650"s
I would like to get one a guy on here said they were like $29 or so and that it was easy to install and made a world of difference. I have the new 650 LE and the battery that came with it seems weak at best after i use the winch and snow b lade for a while, would you recomend getting the more powerful AC batttery or a battery from another co.
Old Feb 4, 2005 | 08:40 PM
WhoDatInDaMud's Avatar
tank/coolant heater I've seen - never a carb heater.
They do wonders for exteme cold weather starting but does it get that cold in WV?
A couple of pumps on the primer lever on the carb will do the trick.
You may want to crank up the idle adjustment a couple of turns in the winter also.
Another good device is the battery minder which keeps the battery charged 100% on a trickle.
I attached the female half of a 12volt accessory cord to the battery and the other end to the trickle
charger and just plug it in when its in the shed. But it gets down to -20 here.
Old Feb 5, 2005 | 08:29 AM
heyyou's Avatar
The 650s have anti-freeze from the engine running through the carbs.
There is no primer on them either,at least not the '04s.
Old Feb 7, 2005 | 02:08 PM
Leaf's Avatar
So far, I haven't had any problems starting mine as low as -30 DegC (-22 DegF) with only the full choke and some light throttle. It does take a long time to warm up though and can't be good on the engine. I wasn't looking at a block heater but a magnet heater. Canadian Tire has a new style of heater out for $20 Can. It's a magnet block with an extension cord that plugs in the 120V wall plug. I'm thinking of trying it.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Ty Speece
Jul 2, 2015 04:59 PM
wildbill59
Jun 20, 2015 02:26 PM
OLDSTER
Jan 9, 2001 10:13 PM
