400I Cylinder ?
Just tore down my 05 400i FIS. I checked the cylinder with inside mic and it seems to have a taper in it. I checked it at the bottom of the cylinder and it seems to have a taper a couple microns in about 40mm length. Does this sound correct ?
Unless you ride full time for a living, I don't see how you can possibly have enough miles to require a teardown, unless you did a major no-no. The book says taper should be a max of .05mm or .002" max. The difference between the top and the bottom diameter. I generally check from the top of the ring wear to the bottom of the ring wear first and then from the top of the ring wear to the bottom of the jug. One lungers get a lot of piston slap.
Another question for ya Bear. I just tore down a 04 400 Cat for a friend. He just bought it a couple weeks ago. It was smoking pretty bad. When I got the cylinder off it was scratched pretty good, a 50 over bore should take care of it. Anyway.....to the point........ I took the cylinder to the local Arctic Cat dealer, he told me that the 04 and 05 cylinders where nickel <SP?> plated, is this so ? I took the cylinder to a Honda dealer that I use alot, they said they would order the piston and rings and bore it for me.
Originally posted by: Wilburnga
[img]i/expressions/face-icon-small-smile.gif[/img] I wish I rode for a living. I have around 1500 miles on it, we have alot of sand in the mud on the mountain I live and ride on. That stuff makes a great lapping compound [img]i/expressions/face-icon-small-smile.gif[/img] Sucked a bunch of it through my carbarator, ate the rings up. Thanks, I'm well within the 50 microns then.
Originally posted by: toyaddict
I know for a fact that the 05 400 bores weren't nikasil, But I dont know about the 04.
