need help removing cv on 454 4x4
Is there a trick to removing the passneger side front cv on a 97 454 4x4? I have tried prybars and such
with no luck. On all the car axles I have took out a pry bar behind the inner joint will break the snap
ring loose. Does this cv have a snap ring or is something else holding it in? thanks
