2005 250 Plug Problem
Old May 27, 2006 | 06:03 PM
DJH1's Avatar
Default 2005 250 Plug Problem
I just bought a AC 250 2x4 about a month ago, haven't even put a full tank of gas through it. I got on it the other day, and the thing wouldn't start. I changed the spark plug and it ran like new, better than new!! I was ecstatic to say the least. Well after about an hour of riding yesterday and my wife putting around the yard this morning, I went to start it this afternoon. It didn't crank right up like it has since the new plug, but ran OK. I pulled the plug out and sure enough, it's black as can be. I talked to a guy at the dealership over the phone, and he said I may not be turning the choke off all the way when riding. Well, that's the thing, I haven't even had to use the choke to start it, so i know I'm not leaving the choke on. Any ideas on what's fouling these plugs??
Old May 27, 2006 | 06:28 PM
Bear4570's Avatar
Two things, choke lever is off in the UP position and are you turning the fuel valve off when not running? You should have to use the choke to start a 250 when it is cold, even on a warm day.
Old May 27, 2006 | 11:11 PM
DJH1's Avatar
I've got the lever in the UP position. Hmmmmmmmm, I haven't been turning the gas off when not riding. Didn't know that would foul the plug. You think that will cure the problem??
Thanks for input
Old May 27, 2006 | 11:23 PM
Bear4570's Avatar
It can foul the plugs and also give you hard starting if the needle and seat are a little weak and bleeds fuel into the intake system while the engine is off. You should always turn the fuel off when not running for overnight or longer periods of time with a gravity feed fuel system. I set the limit at and hour for turn off.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
Land_shark1
Jul 10, 2015 12:53 AM
Shifts
Jul 3, 2015 07:59 AM
hoopduerr
Jun 1, 2015 08:22 PM
