overheat problem
Old Jun 13, 2006 | 06:11 AM
brithan's Avatar
Default overheat problem
I have a 2000 AC 300 4x4 with a overheat lite that comes on once in a while. It's oil cooled, the radiator fins are clean, as far as i can tell the hoses arn't leaking anywhere,any thoughts? thanks
Old Jun 13, 2006 | 10:47 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Does that thing have a fan? Is the fuse blown?
Old Jun 13, 2006 | 12:24 PM
woodsracertofast's Avatar
it could be a bad cencer or someting, if it is a 300 you may be riding it a little to hard.
Old Jun 13, 2006 | 01:23 PM
Bear4570's Avatar
I had a high resistance short causing my light to come on once in a while. I have an infared temp sensor (cheap at $50 to $80 at Sears or Harbor Freight) and the motor was fine. Finally found the dirty connector from the insturment head to the main harness in the bike. Cleaned out the corrosion/dirt and the problem has not repeated. BTW, I installed the fan on my 250 (same crankcase and cooling system as the 300) before I found the problem and it changed nothing. But it is a nice safety feature if you ride in hot areas.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
J-Mack
Jul 4, 2015 04:19 PM
