What to get, 2003 300 4x4
Old Jun 20, 2006 | 05:51 AM
Bear4570's Avatar
Default What to get, 2003 300 4x4
I have never taken the tire off to change the filter on my 2001 250 (same crankcase as the 300) and see no reason to do so. The filter cover is easy to reach, even on the ground (I use an ATV jack, an item you my get for you ATV). Whenever you work on something for the first time you need to pay close attention. A shop manual never hurts either (there's an accessory you can buy, TROX90). I use to oil the foam outer filter only until I upgrade the filter to a foam filter with the prefilter, now I oil both.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
